Hello memomelo,
First of all, please try to increase your parameters from your system status to be higher, according to our documentation here -> https://forum.tagdiv.com/system-status-parameters-guide/
Please check this topic here -> https://forum.tagdiv.com/topic/cant-save-theme-settings/ because there was discussed this problem about Wordfence plugin. If you have the Wordfence plugin, please disable it or set it according to workaround that was explained in that topic by Bryson T.
