search filter does not work
I try to use the Flex Loop Filters in the Search template, but it is not working.
Is there a way to add filter to search results (filter tags, authors, meta info …)
Do you use flex loop block in the search template?
no, I have used flex block 1.
is there a documentation part where I can read about filtering possibilities?
You need to use the Flex loop Block -> https://forum.tagdiv.com/filters-sorting-taxonomies/
Thank you. This works as intended.
However, the search is now exceedingly slow (>10 seconds). I disabled the cache, without any effect.
Do you have any suggestions how to proceed?
Please provide the link to your website. Also, how many posts do you have?
it here: http://www.zaveza.si.
The total number of posts is ~3000.
Thank you,
We would also like to take a look, so please email us at contact@tagdiv.com and provide the wp-admin and cPanel access. Include the link to the topic in the email.
