Set a slideshow with images, no with posts or categories…
I want to set a slide with images with a link to another page. But with the “slide” element I can only set categories or post’s ids inside of the slide. Is there any way to set the images (with a link to other webpage) inside of a slideshow??
Best,
Mariano
If you want to have a slider gallery you can use the tagDiv slider gallery -> https://forum.tagdiv.com/newsmag-tagdiv-slider-gallery/
If you have the last version of WordPress and you have the Gutenberg, then you need to use the classic editor
– http://prntscr.com/maemeu
– http://prntscr.com/maerse
Hope this will help you!
Hi Calin,
Thanks for your fast answer! But what I would like is to put the slider Gallery in the side bar of my homepage, is that possible???
This is the web. The slider is next to the Pope new. But it is a post’s gallery, no an image gallery… know what I mean??
https://www.styleinternational.es
Thanks and best,
thank you! it works perfect!
Best,
Mariano
Hi Calin,
I have a problem when I use the revolution slider… When I insert the module on the web it works, but the next time I open the TagDiv composer this error comes up:
Errors at columns elements: 2(models) : 3(dom). The model does not match the content
And then the page is completely blocked!! I don’t know what to do…
Thanks and best!
Mariano
This can be caused by plugins, you could make a quick test and deactivate them all, leave only theme plugins active. Check if this solves the problem.
If you made any modifications to the page templates or theme files directly or in a child theme, try to remove them temporarily and test again.
If nothing works, we could take a look. Send us an email at contact@tagdiv.com and provide admin login. Include a link to this topic in the email.
