Another question…
On pages, my posts seem to change order. is there a way to keep the newest post in the main area and have them go from newest to oldest post. Seems the site randomizes them on each page load?
http://www.financialthing.com/peer2peerlending/
thanks
Please read our documentation on block settings: https://forum.tagdiv.com/block-settings-tutorial/
You can change the post sorting order in block setting: http://screencast.com/t/E4iycVhSz4
I don’t see this option?
can you tell me how to get to the options you showed?
thanks
When you add an element in visual composer, the settings for that element will pop up. That is a block 18 I placed on my end. If you somehow close this box you can access it by pressing the little pen icon when you hover on that particular block: http://screencast.com/t/lb4uhyW9Yb Then you have the 4 tabs on top general, filter, ajax and pagination. All of these are mentioned in the block settings tutorial here: https://forum.tagdiv.com/block-settings-tutorial/
I hope this helps
