Hi I need help with the following:
why is the video function is not working on one of my posts – when i click on the link it takes me back to the home page mainnwhile it has it own url
how can i do the sub categorises on the home page block titles like the demo eg affiliate marketing: def, affiliate networks, internet marketing etc…
how can i display the ads on the bottom and the footer of the page on the home page like the demo (728by90) if using the tech demo
How can I get the big banner (block on the homepage – the section that says gadgets if using the Tech Demo)
How to get the ads on the sidebar using the tech demo and what size to use
how to do the editors pick for the footer
how to do author profile with image, how to change the profile image and add details and how to add it both on sidebar and end of a single post
what is the revolution slider plugin use for
You have to be more specific and point us to the link that’s not working because I can’t find it on your site. It could be a plugin issue though. Try to disable all plugins except visual composer and see if it works. If the problem is still there, provide more details.
For the second part, I see you have the categories already set up on your block titles. Provide more details for what you would like to change
You can check the Ads section in our documentation: https://forum.tagdiv.com/above-footer-ad/
The big banner block (gadgets) is actually block 18, which you can use from visual composer when creating pages: http://screencast.com/t/lTJ1Rird
You can read about sidebar ads in our documentation: https://forum.tagdiv.com/sidebar-ads/
The editor picks in the footer section is demo content which comes with the first 8 styles of the footer.
https://forum.tagdiv.com/footer-templates/
You can read more about the revolution slider plugin and its uses here: http://codecanyon.net/item/slider-revolution-responsive-wordpress-plugin/2751380
Thank you
Thanks for your reply, I will have a look at your instructions and get back to u if needed.
Regards
Hi this is link I was talking about that is not working and the video option was not showing. If I click on this posts it will take me back to the home page. http://wp.me/p4cq7A-lG
Which ad option to use if you trying to add ads on the homepage at the middle of the page?
I see that when I click on that link it redirects to your homepage, but I don’t know what post it is. You have this issue only with a specific posts, as I have checked your site and clicked on few articles(standard, video) and did not found any issues. You can check this without any plugins active except of Visual Composer, clear cache and see if you still have this issue.
If the issue persist, send us an email at contact@tagdiv.com and provide more details(the link to the specific article so we can find it on your site) wp-admin access so we can take a look, paste a link to this topic so we know who you are and what your issue is.
To add ads to your homepagepage content via VC pagebuilder, you can use Ad Box block and set the ad you want to display – http://screencast.com/t/bIOp24LJrYC
For posts pages you can use the article inline ad spot and set it to appear after x paragraph – http://screencast.com/t/mG0q0d4qq
