1. After updating to WordPress 5, “Latest Posts” can not be changed.
2. How do I add advertisements between articles, on category pages, and tag pages?
3. How can I add an advertisement underneath the pagination?
4. Images are not appearing on the website. I have used the Regenerate thumbnails but, this is still not working.
5. After I install the Mobile Theme plugin, it appears for all users including desktop users. The grid also is also not being displayed.
1)Try to press the CTRL+SHIFT+R and the option will be available. It’s a caching problem.
2)You should use the Cloud Template Library to customize your category and tag pages because using this plugin you can add the Ad Box everywhere you want on the page.
3)You should use the theme core files and change the position of your ads. If you are not aware of the steps which are needed to take, in this case, please consider hiring a freelancer/developer to help you because we cannot provide custom work at the moment, sorry!
4)After more further deeper investigations, it seems that problem regarding displaying of images happen due to memory caches. First of all, please remove all of the untested plugins and then, clear all of the caches (browser cache, hosting/server cache, purge CDN files if you are using something like this) and then, check the results.
5)Clear all the caches, purge CDN files and check the results. If the problem is still there, please provide your website URL so I will be able to provide a more accurate response.
1. We have tried that option but it is still not working.
2. We have hundreds of tags and categories. To create a custom solution for each one is not possible.
3. We have tried editing the core files. But, the content does not appear on the website. For example:
Attempting to edit the category.php file and place an ad-unit above <div class=”td-main-content-wrap td-container-wrap”> does not appear.
This is just one example that occurs.
1)Send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can further investigate it closer your setup page.
2)Sorry, but please notice that the only way, in this case, is to use the cloud templates, create a category template, an example, and apply it for all of your categories.
3)I do not know how you have edited the category.php file and how you have added the Ads into your category page. Use the Cloud Template and create your category template for your desired category customize it with Ad Spots.
Is there another way to fix the error without giving you credential permissions?
Sorry for the delayed response, seems the topic was unintentionally overlooked for some reason.
1. There is currently an issue when selecting the latest articles template for pages.
While the latest articles template is applied after being selected and the page published/updated, the settings for it are not displaying.
We are working on a fix for this issue however, it will be provided as soon as possible.
2. Between actual modules displaying posts is not possible by a theme setting. With cloud templates you can place ad boxes around the post loop (above it, next to it, below it)
– https://forum.tagdiv.com/tagdiv-cloud-library-plugin/
– http://prntscr.com/lxs30w
Here you can preview and also edit the cloud category templates
– https://affiliate.tagdiv.com/#/load/Category
Each can be imported (and modified if needed), there is also a blank template in which you can design your own templates.
3. The best way to place and ad below the pagination is to use the post loop elements instead of the latest articles section for the template. It is basically the same thing, but the loop can be positioned wherever in the page content, with other content around it
– https://www.screencast.com/t/5tM3cT3Phg99
4. There was a problem with the theme lazyload in the previous version, it is now fixed however. If you have not already, please update the theme, then clear all caching including browser cache. The problem should be fixed.
5. Usually this kind of issue is caused by caching plugin. I have seen before plugins like total cache creating the problem. We tested the mobile theme with WP Super Cache and it works as intended. But some other caching plugins or settings from them can cause the mobile theme plugin to load for desktop users or various other issues.
Please let us know if you have more questions.
