Sharing articles problem with mobile theme on facebook
i have a strange problem.
sharing articles on facebook with buttons within articles not working with mobile theme
once you press the facebook button in the article, it is only shared the site link…
not the photo and description as it has done…
You will have to use seo Yoast for Facebook sharing like this guide suggests: https://forum.tagdiv.com/facebook-share/
Hi Bogdan,
Yes, everything indicated was done. it’s always worked out well.
With desktop is ok, it seems that the problem has come with version 7.6 only in theme mobile.
To understand what i mean try to share any of our artcles via smartphone.
It seems to be ok, but When you share, then control in your account: there is only the site link. Not articles Photo with description like normal is always happen.
  • This reply was modified 9 years by Bintmusic.
I have tested your site but could not see the issue. I was able to share a link and the pot title and photo were present and accounted for. Please try to share from a different device.
Here is a screenshot of my phone: http://screencast.com/t/JYZHksS3j
Hi Bogdan,
Yes I know, It seems correct. But try to push on ‘post’ button. In your page Facebook You dont share what you see in screenshot, but only site link (not article link) without image…
I tested this on our testing site (using the latest theme version and latest seo yoast version) and it works as expected. Simply check this option and it works: http://screencast.com/t/P5vdTumeJ
Please disable all other plugis except visual composer, clear cache and reset cdn files.
Hi Bogdan
have you try with mobile theme sharing from smartphone?
I tried to do everything that you said, but not resolved:
in my site the problem is still there.
All Open Graph meta data are enabled as always http://screencast.com/t/P5vdTumeJ
With 7.5 everything was fine, with 7.6 with mobile theme is the problem, not from desktop.
It seems to work, but if you check on your facebook profile where you shared the link, appears only the url of the site without photos… and not url of articles that you shared, simple url of site..
Yes, I have tried with the mobile theme. If I did not check the open graph in seo yoast it behaved exactly as you described. But once I enabled the facebook OG image, it worked as expected. I tested on mobile phones with the mobile theme active.
Try to disable all plugins except visual composer and seo yoast, clear cache and reset cdn files. Then test again. maybe there is a plugin conflict somewhere affecting the og image.
If you still have trouble with this please contact us on our email address at contact@tagdiv.com and provide a link to your site and wp-admin (login information and admin rights) so we can login and investigate. Please also include a link to this topic.
