Shortcode problem
Hi, I have problem to insert my shortcode, because width the tagDiv Composer no element works.
Can you help me?
I am not sure I fully understand what you are looking to edit. Can you please provide a screenshot and more information about your issue ?
Sorry for my english,
I try to explain because from screenshoot in not clear.
I have a plugin width a shortcode [metaslider id=”12″] to put inside a textarea to run.
Before I used your “text with title” shortcode to make it run, but sometime doesn’t work.
Which other shortcode can I use to make it run?
I hope I have been clearer
Thank you
I’m not sure that plugin which you use it is working with our theme.
But, you can try to use also “Column text” element.
My suggestion is to solve this problem first: https://forum.tagdiv.com/topic/text-with-title-doesnt-work-anymore/
