On the page I link below I use block 15. I’ve set the “category filter” to only display one category of posts.
And to display in “random order”.
However – an annoying thing happens – some of the posts are showing up twice. I only want posts to be seen once in the same block.
Why is this happening?
The page is: http://toppselger.no – scroll down to “Salgsfirma i Norge” at the botton of the page to see the block I’m talking about.
Kind regards
Lars
Hello Larshell,
By default, the behaviour of this kind of feature is that every refresh the images to be changed randomly but if you are using a cache plugin, this feature is directly affected by this and the images will be with cache and then you have the same images until the cache will be empty. For better results, you have to change the time to refresh cache memory from the plugin panel, like this -> http://screencast.com/t/SbVbae2m0GXo For more information about this plugin, please consult our documentation here -> https://forum.tagdiv.com/cache-plugin-install-and-configure/
Thank you for the message!
I’m not sure if I explained myself well.
The issue is that the same post is appearing twice in the same block. That does not look. It should only appear once.
See printscreen of it here: http://www.screencast.com/t/3MweeRR8Lkb
Any fix so the post only shows once.
Best wishes
Lars
