Please let me know what template you use for posts, if you use a template from the theme panel, then you can set it directly in the posts => https://i.imgur.com/M6A2Z9c.png but if you have a Single Post template from Cloud Library, you can create the sidebar with tagDiv Composer, like in this article https://forum.tagdiv.com/sidebars-tutorial/
Also, if you want to create the sidebar in Appearance -> Widgets and set the sidebar on pages, using the element from tagDiv Composer, Widget sidebar https://i.imgur.com/e1FPdYU.png -> https://i.imgur.com/q20UCZf.png
