sidebar problem
after upgrading newspaper 8 my sidebar position changed
now it’s above my article text => https://www.screencast.com/t/CiWw8Rh5DW
how can I solve this problem
Hello israk.m,
Try to disable all the untested plugins which might interact with the theme core files and cause a lot of unknown issues. Clear all the caches and check the results. If the problem is still there, you should make a new clean install from scratch via FTP way.
I have the same problem. I reinstalled via ftp, desactivated all plugin. In my case, the problem appear when I reactivate Visual composer bakery. You advise to rewrite the post on a new page entirely with td composer. Does it mean that we are obliged to make a redirection to the new page in order to avoid duplicate content ?
Try disabling the tagDiv composer plugin and then activate Visual composer. Then see if the problem is solved. The new composer is active by default. This front-end editor should not be used in combination with Visual composer on pages.
Here you can find more information
– https://forum.tagdiv.com/visual-composer-tagdiv-composer-transition/
Simion C,
For me the same!
@monoazulweb
It could be the case that something went wrong when updating the theme. Please try to reinstall it using this method
– https://forum.tagdiv.com/install-via-ftp/
Then check if any problems are still present, while having only Visual composer active. It could also be some custom code, or a child theme that you might be using.
Hi Simion,
I just use TDComposer now, but the entries keep show over the content.
look: https://fefi.com.ar/lanzamientos/nike-tiempo-legend-7-juego-mas-facil
It could the case that you used Visual composer for your posts. That is why they are displaying like that. Try creating a new post with a sidebar if needed for the test, and test if it is displaying properly.
Visual composer is not recommended to be used on posts, but could still be used if enabled in the settings. The tagDiv composer can only be used on pages.
Ok. But If I use VisualComposer the problem is true too
Then something is not functioning as it should. This is how the post page looks at the moment on your website
– http://prntscr.com/g3rxtv
It is not supposed to look like that. There is something wrong with the container, or other elements of the page. Please check if you have any custom code added to the theme files, or child theme active. Deactivate all plugins except Visual composer and other plugins included with the theme, and clear the cache. Then the problem should be fixed.
Most likely this is caused by a plugin, this way you can see if that is the case.
