I am unable to find the widget for posts. Following Dashboard>Newspaper>Theme Panel>Post Settings>Template Settings>Blog and Post Templates and changing the default for posts does not change the sidebar items that appear in that post. I have also tried to change these sidebar items from the actual post and nothing changes. If you visit http://www.onechristianvoice.com and go to any post, I am trying to get to the widget that says, “Don’t Miss”.
Hello Rhonda,
You can edit the post sidebar you select in your post: http://screencast.com/t/eizcHda0C1pO and you can edit the sidebar from the wordpress widget area by adding elements to it (or removing them): http://screencast.com/t/mEzEeeb8pH
You can read more about sidebars here: https://forum.tagdiv.com/sidebars-tutorial/
I hope this helps
