The best way to start using our theme is the docs: https://forum.tagdiv.com/block-settings-tutorial/
You will find much useful information in there and should get you started on your project. We made an effort to make the documentation as user friendly as possible with images and explanations. You can also check out our youtube chanell: https://www.youtube.com/user/tagdiv We upload tutorials there to help our users better understand the theme options.
I hope this helps.
thank you!
