When I have the code in my sidebar ad or remove it, the sidebar ad for posts still remains. Please advise if this is a bug or I need to remove/replace it some other way? Sidebar lower ad issue under latest articles on single post link
You have a single post template from the cloud, so the edits must be done using the tagDiv Composer on the post template, select the ad box element from the sidebar and check the banner from the image ad tab.
Please provide photos because when I edit the template with the tagdiv editor the ad doesnt appear and the only ad tab that appears when selecting any element is the main and there are no ad codes or ads there. The side bar element has no options for ads and the ad is only visible when on the post page not when in the tagdiv editor
First, make sure that you do not use any ad blocker extension.
Edit the single post template – https://i.imgur.com/i92VyrH.png then select the ad box element and check in the image ad tab, usually there are set the banners – https://i.imgur.com/7IocwR8.png
In case you do not see it please provide some screenshots from your ad tab from the general, image ad and custom ad tab
I don’t know what happened but it worked that time and showed up. I got it updated. Thank you for your help.
