First off, great theme, it really has a wide variety of customization opitons, which is a plus.
1) To begin, we were wondering if it is at all possible to display the “Big Grid Full 1” block on mobile the way it appears on the homepage. When on mobile, I only see latest posts but not the “Big Grid Full 1” the way it layed out currently on the homepage.
If so, we would also like to have tabs appear on mobile, say if were to add them on a block like the way this website did it –> hypebeast.com (they have tabs on mobile)
Our Site: https://www.sneakers.tech
2) Also, the animation setting on the theme doesn’t seem to be responding on the latest posts for some reason (block 12). I would like the images to scale when they are being hovered on the homepage as well.
Thank you for your appreciation.
1) I’m not sure how you want the big grid full to display on mobile. It is the same element if you do not use the mobile theme plugin. if so, then the page will get converted as mentioned here: https://forum.tagdiv.com/the-mobile-theme/
As for the tabs you mention on that site, they are present on desktop as well. They are not a mobile only element. Tit is a simple tab element under the grid that will show up on mobile as well as desktop.
2) Only the big grids get hover effects. Standard blocks do not have hover effects.
