Single Post Infinite Scroll Issues Desktop and Mobile
I have created a custom single post off a Cloud Template and have applied the infinite scroll option of the single post template.
Sticky Sidebar
On desktop the infinite scroll works fine, however, the sticky menu on the sidebar doesn’t stick on the new posts that load
Loads then disappears
On mobile, the next post will load but then disappear leaving large amounts of blank spaces.
Example post can be viewed on staging site link – http://akf.f41.myftpupload.com/perth-mess-hall-opening-weekend-food-truck-lineup-27527
I have checked your website and I saw that your infinite scroll is not working well. I checked your console and I saw these errors -> https://www.screencast.com/t/o4Mf6vNNO Also, you are using a lot of unknown plugins which might interact with the theme core files and causes a lot of unknown issues. Remove all of them, leave just to active only the required theme plugins, keep a clear WP install and check the functionality. I have made some tests on my website and it returns well results.
Hi Catalin,
I have fixed the Facebook Pixel and Google Ad errors but now I am seeing the following.
?v=2.0:6 WebSocket connection to ‘wss://public-api.wordpress.com/pinghub/wpcom/me/newest-note-data’ failed: Error during WebSocket handshake: Unexpected response code: 403
g @ ?v=2.0:6
_ @ ?v=2.0:6
o @ ?v=2.0:6
I have also deactivated a number of plugins but doesn’t seem to have helped.
Any further ideas?
Cheers
Adam
Seems rather be a browser problem and not theme related. Try to take a look over that topic from here -> https://stackoverflow.com/questions/39627017/error-during-websocket-handshake-unexpected-response-code-403 Would be useful for you.
I’m not sure what any of that means – bit out of my skill set. Is there anyone that I can talk to further/pay to look under the hood to get this working properly?
Seems that the WebSocket handshake: Unexpected response code: 403 error is now gone but the issues still exists.
Also now for some reason when using the Tag Div Developer the template will load for me to edit but will then disappear 10secs later and leave a blank screen.
Unfortunately the sticky sidebar will not work if you are using the Infinite Loading, sorry!
Please make sure that you do not have a plugin conflict, please deactivate all non theme plugins, also if you are using child theme or cache plugin, please deactivate them, clear all cache and try again.
Hi Calin,
Could you add the sticky fonctionnality on the infinite loading on desktop version ?
Best Regard’s
We already add this feature for the infinite loading on our request list for the coming updates.
