site health problems
https://ibb.co/tzD4Lf9
Below is the interpretation of the image.
I’m installing the plug-in recommended by Newspaper. What’s the problem? An important problem pops up as a notification message. What can I do? Please tell me how to fix it.
1 major problem
Critical issues are items that can have a high impact on site performance or security, and fixing these issues should be a priority.
The page cache improves the speed and performance of your site by storing and serving static pages instead of reloading them every time a user visits.
Page cache is detected by retrieving an active page cache plugin, three requests to the homepage, and one or more of the following HTTP client caching response headers:
cache-control, expires, age, last-modified, etag, x-cache-enabled, x-cache-disabled, x-srcache-store-status, x-srcache-fetch-status.
The median response time of the server is 1,173 milliseconds. Must be less than the recommended 600 millisecond threshold.
Two client caching response headers detected: cache-control, last-modified.
A page cache plugin was detected.
Unfortunately, I do not understand the “problems” from the screenshot, but from your description, it is related to WordPress suggestions to improve the website, for example using a cache plugin that will help you make the website faster.
You can try Wp Super cache (is good but not so powerful), or if you prefer a premium plugin you can use the WP Rocket cache plugin.
Also, please disable and delete all plugins that you are not using.
