Hello support,
My install and customizing of the Newspaper theme went well and the site is now live. But I have a strange behaviour.
The page load indicator keeps running (the one in place of the favicon in firefox) for about 15 seconds.
Looking in Firefox in the Performances I see many calls to setInterval from tagdiv_theme.min.js line 311.
I would like to get rid of this bug and can’t found what’s going wrong here. Could you help please?
Hello lafber,
Ensure that you are using the latest version of the theme installed via FTP way, use only the required plugins and remove all of untested, clear all the caches and check the results. The system status parameters should have to be increased according to our documentation from here -> https://forum.tagdiv.com/requirements-for-newspaper/
Hello Catalin,
I’ve upgrade the theme to 8.8 (themeforest-5489609-newspaper-wordpress-theme.zip).
Upgrade WordPress to 4.6.9
Upgrade tagdiv composer
Upgrade system status parameters to max_input_vars = 5000
Issue still there.
Desactivate each plugin cumulative and event tagdiv composer and issue still there.
Don’t think it is related to any of these as it is js stuffs. Looking at the line in question and setInterval at line 313.
tdEvents.resize_event_medium_run&&(tdEvents.resize_event_medium_run=!1,tdSmartSidebar.td_events_resize(),tdCustomEvents._lazy_callback_resize_100())},100);setInterval(function(){tdEvents.scroll_event_slow_run&&(tdEvents.scroll_event_slow_run=!1,td_events_scroll_scroll_to_top(tdEvents.scroll_window_scrollTop),td_more_articles_box.td_events_scroll(tdEvents.scroll_window_scrollTop),tdCustomEvents._lazy_callback_scroll_500());tdEvents.resize_event_slow_run&&(tdEvents.resize_event_slow_run=!1,tdAffix.compute_wrapper(),
This reply was modified 8 years by
lafber.
I already have a test subdomain.
I’ve experimented some stuffs :
– uninstall my theme (sound radar)
– reinstall it > no more bug
– import my theme configuration > bug came back
– reset the theme in the theme panel import export > no more bug.
So there is something in the customizing of the theme panel that break it. I’ll put them back one by one found the one that bug and come back to you.
OK I found the bug.
Mirroring each settings one by one I finally get it.
I had an image define in Background > Mobile menu / search background > Background Image that was pointing to an ip address and an image. I guess some rest of test at the beginning.
I delete it and everything came back to normal.
