Hi, I need your help to evaluate why website is slow to load.
Maybe I have to change/remove some plugin? I sent my credentials to your email in order to check wordpress.
As you can see from screenshot from GTMetrix https://prnt.sc/RW-m9IgdzE0V
The page took too long to load. GTmetrix tried to analyze the page, but it took longer than 2 minutes to finish loading. Please login to try testing from a test location closer to your server.
Ok I see you answered about images but not about speed load of the website.
Can you check please?
Please note that page speed or optimization is not covered by the support team: https://forum.tagdiv.com/newspaper-theme-support/
Thank you for understanding!
Hi Bettina, I clarify the question:
– I don’t need to make speed optimization, I will do on my own
– I just want to ask if you can at least check if there are plugins that could conflict and if the status of the theme within this application is fine
Could you just check this?
SB
