Site speed
We are having speed issues with our site. We are using managed wordpress from godaddy and for some reason the site is still loading slow on first page. Any ideas?
See theme docs > right side of page under “tutorialls” and DIY, and “best of forums”
There is a page speed tutorial but you will need a bit of know how to do it: https://forum.tagdiv.com/how-to-make-the-site-faster/
Speed booster is the plugin we created for this purpose but it will not work with all plugins as it has a compatibility list in it’s code and some of your plugins could not compatible with it. There is a workaround however. You can remove this code: http://screencast.com/t/RZLIOPUNdqh so it will work with every plugin.
I hope this helps.
