Site speed
Hello, I have some strange problem with unused CSS file – http://prntscr.com/rwltyx
When I manually delete this file, it’s recreating. As I understood, most of the heavy CSS files come from theme plugins – http://prntscr.com/rwlvbb
What I can do to delete this file? Also, I use WP Rocket, and Imagify and minify plugins, so I can’t do anything more to improve loading speed. The only way – to delete this strange CSS file, which is even not in use.
My site URL – https://websiteneophyte.com/
This is a cache file -> https://prnt.sc/rwltyx this is made by the cache plugin you are using.
You can disable the style from here -> https://i.imgur.com/HQHC2or.png
Also I checked your website and the theme plugins are not activate -> https://i.imgur.com/EcYmL26.png please activate tagDiv Composer -> https://i.imgur.com/mFmwmp8.png
If you are referring to page speed, the speed of your website depends on how well your site is optimized, if you follow the steps which are presented in this tutorial here -> https://tagdiv.com/how-to-increase-page-loading-speed/ you’ll be able to increase the speed of your website.
Also you can check this similar topic for more solutions: -> https://forum.tagdiv.com/topic/optimize-script-to-improve-site-speed/ -> https://www.infophilic.com/get-almost-100-pagespeed-newspaper-theme/
– https://forum.tagdiv.com/topic/a-few-tips-for-newspaper-x-speed-high-cpu-usage-issues/
Let me know the results!
Hi! Sorry, I just activate another theme for testing, when you come to my site. Actually it looks like this http://prntscr.com/rwqskv
So as I understood, you recommend me to disable Google fonts? But what if I want to use Google fonts? And how they even connect with an unused CSS cache file?
As I said before I used WP Rocket for caching (best premium cache plugin) and Imagify to compress my images and convert it in WebP format, which is really lightweight, and also I use minification plugin to minify my CSS and Java. So it’s almost all that you can do to improve your website speed, except using CDN.
But as you can see, problem not here. In another free theme, I have a less 1-sec result with the same set of plugins and content.
I turned off google fonts and that’s a result – http://prntscr.com/rwqyv7, as I said, a problem is not here.
We recommend to enable only the fonts you are using, if you are using only default fonts, then you disable the Google fonts if you do not use none of theme and you are using custom fonts -> https://i.imgur.com/IZGhOga.png, then you can disable both.
If you are using now a free theme, then all what you” have on your website will be text and indeed this will be load very fast, but with our theme, you’ll have blocks, images, modules, effects…
From what I see here -> https://i.imgur.com/oAdxdn2.png most of the css is form tagDiv Standard pack, we write an article about the theme plugin -> Newspaper Theme 10: Standard Pack or tagDiv Cloud Templates?, we recommend to replace the elements from standard pack and disable it, in this way the theme will load only the needed css, not entire css like standard pack.
