Hey guys
i’m trying to create a carousel slider with slider revolution, but when i turf on “infinity scroll” option, it shows the green button “on”, i refresh the page and it’s back to ” off ”
i don’t know why.
Hello !
The fact that it is not saving may indicate a plugin issue
Please send us a screenshot of your System Status Tab and make sure that all the requirements are met as you can see here: https://forum.tagdiv.com/requirements-for-newspaper/ ; You will have to first start looking for a plugin conflict. please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Let us know the results.
Thanks Vlad
i need to update my slider revolution plug in (V6.3) , could you remind me how to do it trought the theme ? should i download something ?
Hello !
You will need to re-download the package from themeforest in order to get the latest update of Revolution slider: https://themeforest.net/item/newspaper/5489609
