Smart lists posts how to filter and find them after they were created
Hi there, I am hoping you can help. I have a number of posts built as the “smart posts design” that is available in the newspaper theme and basically I have a number of these posts created over the last 3/4 years and I was just wondering if there was a way to filter or find these posts in the backend of wordpress or find them in the database just to identify which ones are smart list posts and which ones are regular posts as I need to make somre edits to all the smart lists posts.
Obviously I do not want to have to click into each and every post (thousands of posts over the past year or 2) to find the smart lists posts of course.
So is there a clever way to find them on my website backend maybe?
Thanks,
James
Please read carefully our documentation about smart lists from here: https://forum.tagdiv.com/smart-lists/
Hope that helps you!
Hi Bettina, I have gone through the documentation here https://forum.tagdiv.com/smart-lists/ on Smart Lists but maybe I am missing the information on how to find which posts I have already created as a smart list? I see the documention shows how to create a smart list and I know how to do that. I have created many over the years, at least 100 in fact. However I want to find those 100 posts that are smart lists in the backend of wordpress. I explain more here: https://share.getcloudapp.com/wbu98rvw so as you can see from that video I want to be able to find the posts I have created in the past that are smart lists?
I hope this is clearer now. Thanks
Unfortunately, there is no filter implemented there to can extract only posts which has another content like smart lists.
Sorry for the inconvenience!
Ah ok, so not even a way in the database to filter or search for a key tag or phrase to find the posts that maybe a smart list? Ok wow this will be tricky in a list of 5800 blogs!
An alternative could be a script written for you to achieve this, you can contact our custom work team here: https://tagdiv.com/premium-customization-services/
