Social counter, Instagram Widget and Instagram Footer does not work
I have updated the theme to the latest version.I cleared all the caches and checked the results.
And still, nothing works
Can you help ?
That would be unusual, the previous theme version 8.7.3 contained the Instagram issue fix. All the problems that were mentioned after updating were caused by a form of cache, CDN, even browser cache. We could take a look if you could provide a link to your website.
There was an update released today, which also provides some more fixes including Facebook social counter (changelog here)
– https://themeforest.net/item/newspaper/5489609
Hi, I’ve got the same problem. Updated to the latest version 8.7.4, updated the site and cleared all caches. Instagram works for the first time. Facebook counter still 0 FANS. Solution? Thanks
@zoeMedia
Note that the configuration of the social counter has changed, now you only need to add the ID in the required field and it will work
– https://www.screencast.com/t/WCVoEfsLbf5
Check if the theme plugins have been automatically updated, the new versions are these
– https://www.screencast.com/t/SpPm3o9wt5a
In some cases they are not updated automatically, update them manually if that is the case. Let us know.
Same issue here as well. Twitter auto populates with the correct information, but Facebook, Instagram and Youtube show zero.
I have setup the plug in correctly, double check via your link above and I’ve just updated the theme, however it appears that the social counter plug in did not update. I understand you said to update it manually, could you please tell me where I can find the updated plug in.
@bluesybil_2016
Deactivate the social counter plugin and remove it. Install it from here
– https://www.screencast.com/t/p9KKl4oK
Then edit the counter where it is placed and check if it works, it should. Let us know if there is still a problem.
The Instagram feed in the footer built into the Newspaper theme isn’t working for me. I updated the theme this morning. I replaced the instagram id with coca-cola and their images showed up as expected. When I replace coca-cola with my id stoneandsonsworkshop the images don’t show up. Help. website: stoneandsons.net
Hi Simion, I have the same problem with the counter. I did what you told and removed the social plugin. But I can’t seem to find the plugin installation anymore. Where do I find it?
@bsstone13 The Instagram feed seems to be displaying the latest images at the moment
– https://www.screencast.com/t/FxKox42kul1t
Could have been some caching, if you still see older images clear the browser cache.
@brenbrinkman You can install the social counter plugin from the theme plugins panel
– https://www.screencast.com/t/JW4cjwwGU
It is also provided in the theme package, plugins folder
– https://www.screencast.com/t/l8SiZxx7TcoM
– https://forum.tagdiv.com/whats-included/
Hi, I have the same problem. When I replace TagDiv name with my wirtualnestarachowice counter facebook show 0 fans. Any other fanpages shows numbers of fans corect but not main. Pleas help.
Please make sure that your account on Facebook is public not private.
Also your Facebook page need to look like this https://www.screencast.com/t/JpXL9cxIl
thank’s for help. I have to change settings about country view limited.
