hi,
my social counter is not working, facebook like counter is same alltime.
i updated to plugin but not fixed the problem. how i can fix it , please help
my site: gurmdergisi
Hello netimiz,
I have checked your website and I saw that your social counter are working properly now, as you can see here -> http://screencast.com/t/dw790zxpDUz If your problem reappears, please follow the guide below and try to set up as properly ->>
In order to achieve best results, please try to disable all the active plugins, leave just Visual Composer, clear all cache and install only the plugins that come bundled with our theme and rule out the conflicting plugins. After you have done this, please consult the guide below and then check your social counter and see how it works.
1) Please make sure you have the latest theme version: 6.7. If not, you need to follow this guide to update your theme: https://forum.tagdiv.com/how-to-update-the-theme-2/
2) Having the latest version of the theme is not enough if you do not update the social counter as well. You need to remove the current version you use: http://screencast.com/t/4jvRwNzK and then install the version of the plugin that comes with the 6.7 theme: http://screencast.com/t/9AKKURjTjX
You can recognize if you have the correct version of the plugin when you see the new app key settings: http://screencast.com/t/CIXxklBanNl If you do not have these settings in your social counter it means you do not have the correct version.
3)You need to follow this guide to get the requirements from facebook:
https://forum.tagdiv.com/tagdiv-social-counter-tutorial-2/
Please keep in mind that the social counter is not a live count. It will update once every few hours.
Hope this helps!
Thank you for the message!
