social media symbols not showing on mobile
Hi, the twitter, youtube and google+ symbols aren’t showing in the mobile version but they are showing in desktop version although the link to my social pages work correctly in both versions. You can check the problem here http://imgur.com/pJriOGI
and if you open in desktop http://www.carmeneverywhere.com the symbols are there. How to fix it?
Using a custom CSS? You might want to delete your site cache, and recheck?
I don’t know how to do that?
Mmm…First, tell me. Are you using W3 Total cache or WP Super Cache plugin?
No,neither
You should use. I prefer WP Super Cache, it works best with Newspaper theme. You can download it from here: https://wordpress.org/plugins/wp-super-cache/
Instructions for setup could be found here: https://forum.tagdiv.com/cache-plugin-install-and-configure/
I have installed this one http://imgur.com/lYk2mA5
Is that the one you mean? I have turned on caching and debugging. What should i do now?
Yes. Now go to WordPress panel > Settings > WP Super Cache > Contents, and delete cache.
done, and now?
See if it solved anything
no 🙁
Weird, have you tried deactivating and then reactivating tagDiv social counter plugin?
I have checked your website and the social counter icons are displaying as they should: http://screencast.com/t/TkcqYUbPq
