Specific Post from specific category not showing in Flex Block2
Filters and sorting are not working properly for flx block 2
Please provide some screenshots or a video with the settings you applied in order to check and help you.
I am not able to attach a screenshot please suggest
1)Whenever i give post in filter option of Flexblock 2 it will show no post in the box .
screen shot is attached
https://www.screencast.com/t/DZxI4B13V
2) I have added a new post but when ever i select a specific category and set sorted as latest it is not showing the latest post
https://www.screencast.com/t/hzpctiBgq
website url is Indiaworldview.com
Please do the needful
Please make sure you have set the right post id, and if you want to add more posts please separate the ids with commas -> https://i.imgur.com/Yljq3fh.png
Also, make sure you don’t have offset on the block, please edit with tagDiv Composer, select the block and let the offset field empty with no space, no value and see the results: https://www.screencast.com/t/peVbVmUDE. For more information about the offset features, please check this tutorial: https://forum.tagdiv.com/offset-feature/.
Hi ,
I am adding the correct post id for the specific category ,Please find below the screenshot for the same.
https://www.screencast.com/t/Is3cHlzaI0Pl
https://www.screencast.com/t/mY6R0zo2eg
geing no pos found please do the needful i want only single post to be visible in my flex box only the specific post
As I said above, please check if you don’t have set an offset on the block.
