Speed ​​Booster akismet.php problem
http://i.hizliresim.com/oEk3z9.jpg
what should I do?
My turkish language ..
[ Bu sorunu çözmek için ne yapmalıyım ? ]
Note that the Speed Booster plugin disable itself when an incompatible plugin it’s installed. We added this measure to avoid conflicts with the plugins that won’t allow to move their CSS/js resources at page bottom. To keep it always activated comment or delete the indicated lines from td-speed-booster.php: http://screencast.com/t/RZLIOPUNdqh You can check this topic for more information about speed booster usage: https://forum.tagdiv.com/topic/speed-booster-questions/
Hope this help.
Hi Andrel;
Problem solved. Thank you so much..
There is one more question;
http://i.hizliresim.com/1NgGvj.jpg
Desktop 95/100
Mobile 72/100
what should I do?
Best regards..
HI
We covered in our documentation most important aspects google notifies you about in page-speed regard: https://forum.tagdiv.com/how-to-make-the-site-faster/ According to google’s report you can reduce the load time by enabling compression for static resources. Fore more details please check these links: https://developers.google.com/speed/docs/insights/EnableCompression – https://gtmetrix.com/enable-gzip-compression.html – https://gtmetrix.com/leverage-browser-caching.html
To remove render blocking resources you can use our Speed Booster plugin as we indicated in our documentation at pint 5. Fore more details about page-speed please also check these topics: https://forum.tagdiv.com/topic/site-slow-down-caused-by-style-css/ – https://forum.tagdiv.com/topic/speed-is-slow-after-updating/ –
Note that you will need a bit of codeing and some customizations in order to achieve a good score for your site. We can’t offer speed customization services at the moment, most we can do is to point a way of improving. If you still need guidance on this or you’re not aware of the steps you need to take in this regard please consider hiring a developer or a freelancer to do this for you.
Thanks for the answer. I could not do this problem :))
http://i.hizliresim.com/9GdnXN.jpg
http://blog.teamtreehouse.com/wp-content/uploads/2015/05/InternetSlowdown_Day.gif
It can be solved by preload ? No theme preload.. I couldnt find it. lazy load external ?
Best regards
HI
The indicated image does not appear in google’s report. If you still need assistance on this please provide more details a bout your issue and maybe I can help.
Ok!
Thank You So Much..
