Speed ​​optimization
Is it possible to deactivate functions / filters or modules in the theme in order to operate the theme more efficiently? (e.g. Multipurpose Feature etc.)
Please provide more details about what you want to deactivate, so I can let you know what can be done. For multipurpose feature, you need to modify the code of the theme and plugins, which I not recommend.
for example: modal login feature in the frontend
ajax live search
For modal popup login, you can simply disable the login from backend and remove it from the frontend using tagDiv Composer https://forum.tagdiv.com/login-how-to-enable-user-registration/ after that if you want you can also comment the code from the theme files wp-content/plugins/td-composer/legacy/Newspaper/parts/header/td-login-modal.php and wp-content/plugins/td-cloud-library/parts/tdb-login-modal.php
Also for live search, all you need to do is to remove it from the cloud header with tagDiv Composer and replace it with the search form element.
awful web vitals disastrous update uninstalled and reverted to version 11.2
