Here is the problem
http://gtmetrix.com/reports/portalespigao.com.br/SmFOWasP
Your server is loading toooo slow.
And you need to regenerate some thumbs
Right .. well it’s a new theme not a dot update; all the grids, layouts, images CHANGED.
You need to regenerate your thumbnails to fit new layout, hence all the resize image errors seen in the GTMetrix check. Also need to update any tagdiv plugins, clear server side cache if using one, etc.
Optimize that one image which is 23KB too large (see the report link for which one).
When you change themes you need to regenerate thumbnails to fit the new modules/layouts/sizes.
Theme can’t do that for you, unfortunately.
Also this may help: https://forum.tagdiv.com/how-to-update-the-theme-2/
@Roney
Before update please backup the site (database and files) – https://codex.wordpress.org/WordPress_Backups And follow the documentation to update – https://forum.tagdiv.com/how-to-update-the-theme-2/ run the script and regenerate thumbnails.
Thank you, the problem was solved with the response from Chris S http://gtmetrix.com/reports/portalespigao.com.br/cjCwPKeE
