Speed and Bug
I bought the theme today but it seems it doesn’t meet the requirements. The following are the details –
1)Speed
To build a faster site, I have installed LAMP from the Digitalocean.com marketplace and installed your theme with a fresh WordPress installation.
I didn’t import any demo but create a simple homepage using the tagDiv Composer and also installed only these plugins – tagDiv Composer, Akismet, WP rocket and Yoast SEO.
I am only using 4 plugins but there is still getting some speed errors in different speed test tools.
FOR PAGESPEED INSIGHT
a. remove unused CSS
b. serve images in next-gen formats
c. Reduce server response times (TTFB) which is 0.29 sec
check this screenshot: https://prnt.sc/qoxt3l
FOR GTmertix
a.Leverage browser caching – 52 grade which is taking care by wp rocket.
b. optimize images
However, waterfall just loading 1 css, 2 js internal, 1 font file and 7 images.
Check the report here: https://gtmetrix.com/reports/gyantimes.in/TH71VBlG
I have also followed your guide available at https://tagdiv.com/how-to-increase-page-loading-speed/. Unfortunately, i found no improvements.
2) There is no options in the theme panel to change the footer copyright after disabling tagdiv standard pack plugin. screenshot: https://prnt.sc/qoy62e
3) Post sharing plugins only showing nevada green button.
However, I am using the simple feature that a default wordpress theme can provide but still i paid $62
This is not a small amount for me to invest in a starting website.
Yesterday, I have created this ticket within your working days and time but still, I didn’t get any support that looks like an unprofessional service.
Hello !
1. In order to have a relevant page speed we suggest you to follow our requirements and page speed documentation (which you did ) and after that start posting because an “empty” website will not be relevant for your users in the future. Also please note that page speed is not controlled only by the theme. There are other factors like Host, number of plugins, images, all these influence the Theme.
2. If you don’t have standard pack you will have to edit or create your footer page in order to edit it. Find out more about it here: https://forum.tagdiv.com/footer-templates/
3. f you’re seeing only NAVER
This issue happens when updating from an older version of the theme so please make this adjustment in the tagdiv composer plugin:
https://www.screencast.com/t/HGX40TlcJgb
Then hit a save in the theme panel and then revert the code back to original .this will make the social icons appear properly again.
Please note that we answer the topics from Latest to Newest Monday – Friday from 08:00AM to 05:00PM GMT+2 So multiple replies to your topic will only make us to get harder to your topic.
  • This reply was modified 6 years by Vlad S.
I am using vps server and using only 4 plugins, it should give ve 100 score. But Pagespeed is asking to remove unused css from your theme. What are those css style that are not in use?
hello !
As you can see here, most of the problems come from external plugins: https://www.screencast.com/t/RCM0dcT6R
Also note that scoring 100points… that is a big task that doesn’t come only from the theme. All your plugins must be set perfectly because as you can see they affect it too.
I hope this was helpful !
The example you are showing from the world’s best caching plugin – wp rocket which is far better than the wp super cache.
Hello !
Please note that scoring a page speed of 100 is not necesarily impossible but your whole website has to be optimized.
For the unused css you can try a 3rd party optimizer but we have not tested any in order to recommend it.
Thank you for your understanding !
I have been working with my web hosting company and I am experiencing similar issues. Google PSI indicates that I need to “remove unused CSS” and my web host provider said the following CSS were the issue. This is causing an extra 1.5 seconds load time:
/wp-content/plugins/td-composer/legacy/Newspaper/assets/css/td_legacy_main.css?ver=5a862b9d7c39671de80dd6dee389818b
/wp-content/themes/Newspaper/style.css?ver=9.8
/wp-content/plugins/td-cloud-library/assets/css/tdb_less_front.css?ver=489325fca4f12cbec6ded350cf173551
Appreciate your help.
Hello !
You are suggesting to remove the basic style.css of the theme there and it is not recommended by our team.
For page speed you can contact our custom work team in order to improve your page speed. You can find them here: https://tagdiv.com/premium-customization-services/
It’s absolutely ridiculous that you’re suggesting we hire your team (who botched the pagespeed to begin with) to fix the pagespeed issue we’re all seeing relating to unused plugins.
The style sheets are slowing EVERYONE WHO USES NEWSPAPER down, and you guys keep giving canned responses to ‘check out how to speed up your site here’, which doesn’t resolve the issue AT ALL.
We need a solution.
Hello @nerdmuchcom
I have inspected your website.
As mentioned above, page speed is set by all the content of a website. Keeping that in mind, your page speed is not affected by the Newspaper Theme. Is affected by the number and type of ads that you are running as you can see here: https://www.screencast.com/t/Zkib2CYO9
