Speed Booster
hello i want to ask something, i installed Speed Booster plugin why in system status not green? and out read v4.9.1 – Disabled – incompatible plugin detected please help me. thank you
https://i.imgur.com/VbPeYoG.png
The Speedbooster plugin has an inbuilt plugin checklist, if it detects plugins outside that list it will deactivate itself. This is supposed to happen, as the Speedbooster plugin could cause some plugins to not function properly.
The checklist could be disabled by modifying the plugin code
– https://forum.tagdiv.com/topic/tinymce-advanced-and-other-various-disabling-speed-boster/
Then test to see if everything works properly regarding plugins installed.
The link goes to a 404 page.
Nvm
