Speed Booster Conflicts
Hi, is there a workaround for SpeedBooster? It seems to be the only remedy for Render Blocking js/css issues but the plugin conflicts with many many other necessary plugins, even basic WP ones like Askimet.
Will this process work with conflicts?
5. Remove render blocking css/js – using the TagDiv SpeedBooster plugin (advanced users)
Render block is heavily penalized in SEO. I would be surprised if there is no workaround.
Thanks for any insight anyone may have.
You could maybe try other booster plugins, or render blocking plugins. Make tests with them, they might also have more options and settings.
Our plugin will automatically deactivate itself if it detects plugins that are not part of a predefined list in it’s code
https://www.screencast.com/t/2DORngA6lc
This check could be deactivated and it will be active permanently, but that may cause problems with some plugins
https://forum.tagdiv.com/topic/tinymce-advanced-and-other-various-disabling-speed-boster/
Thank you Simion. I will do some experiments. I appreciate the links!
~r
