Speed Booster CSS Flash
Since I have upgraded to Speed Booster 2.5 I get this strange Flash of CSS code on my website for a few seconds. See: http://goo.gl/v3nDL1
When I disable the plugin, the codeflash is also gone.
How do I fix this?
Thanks you
This issue it’s in our todo list and we will fix it in one of the next updates.
Sorry about this!
@Lucian, there’s also this issue of the original css loading first (fonts and colors) and then the custom css. Makes for a bad user experience in my opinion.
This is a common issue using the speed booster plugin, regarding theme color you can try this solution.
Regarding fonts you can try to remove the fonts you don’t use from here and see if this makes a difference.
Of course the best way would be to disable the plugin.
Also try to delete and install the speed booster plugin from the latest theme version files (4.2) I have tested this and seems that this issue don’t happen anymore.
  • This reply was modified 12 years by Lucian.
Hi Lucian,
You are right, reinstalling the speed booster 2.5 fixes it (in combination with theme version 4.2).
