Speed Booster – incompatible plugin detected
Speed Booster: v4.9.3 – Disabled – incompatible plugin detected: akismet/akismet.php
How can I this fix issue on my site https://www.jogira.com/
Note that the speed booster will be deactivated if it detects plugins that are not part of this list
– https://www.screencast.com/t/TqHrzrA6y
This check could be disabled and the booster will always be active
– https://forum.tagdiv.com/topic/tinymce-advanced-and-other-various-disabling-speed-boster/
I believe this measure was implemented because the booster could cause other plugins to not work properly. The plugin is optional, not required. So if it causes problems you should deactivate it.
