Speed Booster is always disabled even after i was edited td-speed-booster.php
Hi all,
i was folowed to this instruction https://forum.tagdiv.com/how-to-make-the-site-faster/ to install Speed Booster plugin
after that, i edited file td-speed-booster.php by this guide: To always enable speed booster, delete this code: http://screencast.com/t/RZLIOPUNdqh
but theme system status still display: v4.9.3 – Disabled – incompatible plugin detected…
system status capture
i have some plugins not in allowed list, i think they need for my site
Anyone can help to always enable Speed Booster?
Thank you so much!
Did you have read the warning regarded to the Speed Booster disabled? -> https://www.screencast.com/t/AydfRuzBDWr
The speed booster is an optional plugin and it is tested only with these plugins – http://screencast.com/t/hcjLnOqh4i2 and if you use other plugins it will be automatically disabled. A lot of people install the plugin without knowing what it does and after that, they add many plugins and some of them are not written fine so the developer took this decision. If you want to always enable speed booster, delete this code from speed booster file: http://screencast.com/t/RZLIOPUNdqh
Thank you for your message!
Maybe I did not explain clearly or you read it so quick.
I mean I read all the issues, follow the instructions, even editing the td-speed-booster.php file but still Disabled.
Surprisingly, after many hours of installation and modification, the system status display Activated.
And now the images on Module Flex 1 are cropped above and below.
There are 3 issues here:
1. I did not install any plugin cache, why my modifications take many hours to refresh.
2. Images on Module Flex 1 are cropped.
3. The js moved but the css style of the theme and child-theme wasn’t move to the footer.
Is the plugin error?
So the speed booster plugin finally activated. This should not be so difficult, all it requires is that the plugin be installed and activated.
If the booster detects plugins that are not part of the list mentioned above, it will have an inactive status.
If there are no such plugins it will have an active status.
If you remove the code as shown it will be active at all times, but note that it can create problems with your plugins. They might stop working or not function correctly if their resources are moved.
1. Maybe the hosting provides a cache system, you could contact them and ask about it. The theme has no caching by itself.
2. So there is a difference regarding how the flex block modules display with and without the speedbooster? We could take a look at that.
We will require admin access to your website, send the details by email at contact@tagdiv.com and also include a link to this topic in the email.
3. The loading of the theme CSS and also the child theme CSS should be moved. I also tested this and it works
– https://www.screencast.com/t/3sjfUzec
I checked this using only the allowed plugins and also with the code removed from the plugin, both the CSS are moved.
Thanks for reply,
1. I asked the hosting supporter for cache and he showed me hot to disable opcache on server.
2. I fixed images cropped on Module Flex 1 by modified the child theme
3. I tested my site again with Google PageSpeed and they showed 4 css are render-blocking include td-composer css and theme css
” alt=”css render-blocking” />
i was send acount info to contact@tagdiv.com
