Due to an oversight, it seems that tagDiv composer was not included in the list of permitted plugins. This will disable the Speedbooster. We will make the necessary modifications in the next theme update so it will not be inactive when the tagDiv editor is detected.
You could remove the compatibility check as mentioned in this topic
– https://forum.tagdiv.com/topic/tinymce-advanced-and-other-various-disabling-speed-boster/
Hello, we are getting a message in the System Status as below:
Speed Booster – v4.7 – Disabled – incompatible plugin detected: advanced-ads-pro/advanced-ads-pro.php
This is the plugin that it is conflicting with https://wpadvancedads.com/add-ons/advanced-ads-pro/
Can you help us know, how can we know what is the exact problem that is causing this error?
That is not an actual error. The Speed booster is an optional plugin that will not activate itself if it detects different plugins then a predefined list. This check can be disabled if it is necessary. Please follow this topic for more information
