Speed booster not being updated by theme color
After changing the theme color the speed booster keeps the old one. Even if I disable and enable the plugin, the old color before the theme color change remains.
We will release soon an update that will fix the color issue with Speed Booster plugin.
What do I do in the mean time? I really need the Speed Booster plugin, it amazingly chops off entire seconds in site load times.
hello,
please update to the latest version.
Thanks for you message.
Radu A.
Where can I find the update?
On themeforest, re-download the theme and make the update.
