Hi, i have a problem with tag Div Speed Booster plugin. I have follow your guide -> https://forum.tagdiv.com/how-to-make-the-site-faster/ but when i insert the script for printing all style and all script registered, these are not all. I have insert my site on the Google Page Speed but the scripts and styles of render blocking resurces don’t match with the script printed. I can’t find a single one and i can’t optimize them. How can i do?
I think that is because the plugin is disable like this -> http://prntscr.com/pjfd5b f is so then you need to go in wp-content/plugins/td-speed-booster/td-speed-booster.php -> https://www.screencast.com/t/RZLIOPUNdqh
Hi, Thank you but is not the problem. Speed Booster in my website is active. The problem is that I can’t find the scripts that tell me page speed. The scripts that print speed boosters are different. I am attaching two screenshots.
Page Speed Results -> https://prnt.sc/pjh8f7
My Scripts & Styles -> https://prnt.sc/pjh952
For example: The style of Newspaper Theme, Newspaper Child, td-block-library, tdb_less_front.css, td_legacy_main.css there aren’t.
The Speed Booster plugin do not tell the page speed, all that is doing this plugin is to load the scripts at the end of page, after the html is load not before.
If you want to check your page speed please check with:
https://developers.google.com/speed/pagespeed/insights/
https://gtmetrix.com/
Sorry but you can’t understand the problem. The scripts that are shown by Speed Booster, are different from those of Page Speed. I can’t find the scripts to be moved to the footer. From the screenshots, i showed you that in the list of scripts that generates speed boosters, there is not even one that matches those of blocking resources on PageSpeed. Do you understand? If not I try to write in Italian if there are any misunderstandings.
I think that you want to move in footer more links for style and java-script, if is so then I can help you to move some css from our theme in footer, you’ll need to go in -> wp-content/plugins/td-speed-booster/td-speed-booster.php -> http://prntscr.com/pkewly
-> https://prnt.sc/pkep1d -> https://prnt.sc/pkepc7 but please notice that some style/scripts need to be load at the top of the page in order to your website to work correctly.
Then the ID of the script/style is the corrispective of the HTML Tag? Okay.. I try to do this, but one last question. I try to use Autoptimize for the cache and it remove all script/style from render blocking resources and don’t crash site. Why?
