There have problem with speed booster plugin in page speed insight render blocking java script and css not move in the footer and also plugin not see on my dashboard menu please help me regarding
Thanks in advance
my website link below:
http://bit.ly/1O7Hkdu
Hello mayurt123,
The way Speed Booster improves site’s page speed it’s moving some CSS and js resources, which usually are loaded in the header, to the footer, such that the browser can loads the content faster. Please note that the plugin was intended for the advanced user, it requires modifications on the code to add new resources (js and CSS) which are moved to the bottom of the page and conflicts may appear because some plugins may cause issues when you try to move their resources at the page bottom. To avoid conflicts we decided to keep the Speed Booster active only for a limited number of plugins, which are tested and works fine even if their resources are moved at page bottom. Checking a plugin’s behavior when Speed Booster is active can be done by adding it on allowed plugins list: http://screencast.com/t/dCMffJFq
For more information about how to make the site faster, please consult our documentation here -> https://forum.tagdiv.com/how-to-make-the-site-faster/ In this tutorial you can find some advice how to Remove render-blocking CSS/js – using the TagDiv SpeedBooster plugin but for advanced users.
Hope this helps!
Thank you for the message!
I already try to deactivate plugin but there are all plugin not supported with your speed booster plugin then how can i made my website if no any plugin support with this. only speed is not enough all factors are important for website
so please help me how can i solve
Hello mayurt123,
Our Speed Booster plugin has been designed to work properly with some tested plugins, as you can see in this screenshot -> http://screencast.com/t/ojSRErqBEI8 Please note that the Speed Booster plugin disable itself when an incompatible plugin it’s installed. We added this measure to avoid conflicts with the plugins that won’t allow moving their CSS/js resources at page bottom. To keep it always activated comment or delete the indicated lines from td-speed-booster.php: http://screencast.com/t/RZLIOPUNdqh You can check this topic for more information about speed booster usage: https://forum.tagdiv.com/topic/speed-booster-questions/
I can add incompatible plugin in speed booster file there are after chek system status speed booster look active supported with all plugin wich i added but i tried to move footer some java script and css which see in pagespeed insight that scripts not move in footer i tried according to your suggestion and also try some various thing but all scripts are not moved in footer
please help me
Please note that speedbooster does not automatically move ALL render blocks to the footer. You will have to manually move a few of them: See part 5 of this tutorial: http://www.alltomtrav.info/dev/daniel-reden-infor-v75-pa-gavletravet-2/
Be careful though as some render blocks need to stay in the header for them to work. You will have to know what you are doing otherwise you could cause more problems than you fix.
