Speed Boster disabled – not work with Akeebabackup
in theme config – Newspaper system stauts we have this massage:
Speed Booster v4.9.1 – Disabled – incompatible plugin detected: akeebabackupwp/akeebabackupwp.php
But we need Akeeba!
What can we do, that Speed Booster works with Akeeba?
Regards, Frank
The Speedbooster plugin has an inbuilt plugin checklist, if it detects plugins outside that list it will deactivate itself. This is supposed to happen, as the Speedbooster plugin could cause some plugins to not function properly.
The checklist could be disabled by modifying the plugin code
https://forum.tagdiv.com/topic/tinymce-advanced-and-other-various-disabling-speed-boster/
Then test to see if everything works properly regarding plugins installed.
