Hey, I installed Tagdiv Speed Booster and uninstalled all incompatible plugins. But when i install AMP (Suggested by you) it is showing plugin incompatible. You know everyone needs AMP plugin but your speed booster pluging is not working with it. Please give me some solution.
Hello !
Please make sure that you have followed carefully all the steps that are being found here: https://forum.tagdiv.com/how-to-make-the-site-faster/
There is however a workaround if you truly wish to use speedbooster with your current plugins, you can make it work by removing or commenting out this code here: https://www.screencast.com/t/RZLIOPUNdqh
