I use the Autoptimize Plugin. I tried Speedbooster but it’s complex and it also gave me 16 instances of where JS/CSS were blocking.
When I conducted the test after the 7.6 upgrade, I was slower and no longer in the green on Google
Much of the issue has to do with Google Fonts. When I did test on Pingdom, it said that Is should combine files
From Pingdom:
“There are 4 CSS files served from fonts.googleapis.com. They should be combined into as few files as possible.”
I am not advanced. How can I resolve this?
my blog is http://www.hotcupofbeauty.com
hotcup
The google fonts are different fonts and our theme cannot combine them into one single string. If you use many fonts you will see this happening. Please try to use only one or 2 fonts on your site. We have 2 default fonts already so 2 are already loaded. If you use 2 more, then they will be 4 loaded. As for the rest of the page speed issues, you should follow this guide: https://forum.tagdiv.com/how-to-make-the-site-faster/ as your site is not optimized.
For advanced use, it’s good to “unhook” the fonts from being enqueued in the theme functions file, and you can combine them as so:
https://fonts.googleblog.com/2010/09/optimizing-use-of-google-font-api.html
for advanced users, you actually capture the CSS from google and put at top of you style.css file.
I cover this a bit in my long winded tutorial thread on optimization in the docs > tutorials > DIY/best of forums
That might not help, but perhaps give you juice to go on an adventure on learning to “super optimize” Google font loading fpr best pagespeed (how I get 100/100) đ
