speed up your site without td-speed-booster
hi,
1. I have some problems with your td-speed-booster plugin version 4.5 does not work with plugins Cache Enabler and WP CDN Rewrite. Creating gaps post to google and GoogleNews.
I also tried Wp Super Cache, but caused a website blocking.
I want to bring in the footer deguenti file:
https://fonts.googleapis.com/css?family=Open+Sans%3A300%2C400%2C600%2C700&ver=4.7.2
https://fonts.googleapis.com/css?family=Roboto%3A400%2C300%2C700%2C700italic%2C400italic%2C300italic&ver=4.7.2
https://static.site.com/wp-content/plugins/js_composer/assets/css/js_composer.min.css
https://static.site.com/wp-content/themes/Newsmag/style.css
https://static.site.com/wp-content/themes/Newsmag/js/tagdiv_theme.js
With your plugin could do it, I would need a code to be entered in the file function.php
otherwise you will have another solution with another plugin ??
2. Then another question, I can minimize the following files, on the advice of google speed, or cause errors:
I look forward to new about and do not tell me I need a technician, otherwise return thema and I turn to others and make you a bad publicity.
Hello orlando,
I will not tell you to hire a technician, but please keep in mind that you should do it yourself the site optimization because we cannot provide this type of services at the moment, sorry!
First of all, the above plugins which you mean, are not tested with our theme, and we have no idea about the theme behavior with these, sorry!
As you can see, the speed booster will be automatically disabled if you will use some untested plugins. The Speed Booster is an optional plugin, and it works only with the tested plugins.If you use other plugins, it will be automatically disabled, and I suggest to check this first in System Status. However there is a workaround to make it also work with other plugins, you can read more here – https://forum.tagdiv.com/topic/speed-booster-not-compatible-with-vaultpress/
Unfortunately, the time doesn’t allow us tot provide any custom and optimization services. We provide support only for the theme related issues based on Envato support policy – https://themeforest.net/page/item_support_policy I suggest to get someone to help you if you want to optimize your site.
We recommend our speed booster plugin to increase your page speed and also, you should read our guide carefully because there you will find all the steps which are needed to take in this regard. Also, there you will find a method on how you can minimize the style.css file and also if you are using our speed booster plugin, the js file will be automatically minimized.
