Starter problems configuring
Can you tell me whether there are any known issues running Newspaper X on EasyWP WordPress servers operated by Namecheap?
I have cloned a live site from there to my own server to change over to Newspaper X but a number of problems are arising.
1) When I try to use TDComposer to edit the homepage I got a 500 Internal Server error. The server log entry was:
Fri May 15 09:20:08 2020] [error] [client 86.168.47.31:0]
[Fri May 15 09:20:08 2020] [error] [client 86.168.47.31:0] mmap() failed: [12] Cannot allocate memory
[Fri May 15 09:20:08 2020] [error] [client 86.168.47.31:0] End of script output before headers: post.php
I spoke with the server company and they advised to increase server memory in php.ini and wp_config to 512m which I did but this did not resolve the issue.
2) Other errors are:
[Fri May 15 09:30:40 2020] [error] [client 86.168.47.31:0] PHP Warning: Use of undefined constant TDC_PATH_LEGACY – assumed ‘TDC_PATH_LEGACY’ (this will throw an Error in a future version of PHP) in /home/sites/terryally.com/public_html/newsroom/wp-content/plugins/td-composer/td-composer.php on line 109
[Fri May 15 09:30:40 2020] [error] [client 86.168.47.31:0] PHP Warning: Use of undefined constant TDSP_THEME_PATH – assumed ‘TDSP_THEME_PATH’ (this will throw an Error in a future version of PHP) in /home/sites/terryally.com/public_html/newsroom/wp-content/plugins/td-composer/td-composer.php on line 113
[Fri May 15 09:30:44 2020] [error] [client 86.168.47.31:0] PHP Warning: Use of undefined constant TDC_PATH_LEGACY – assumed ‘TDC_PATH_LEGACY’ (this will throw an Error in a future version of PHP) in /home/sites/terryally.com/public_html/newsroom/wp-content/plugins/td-composer/td-composer.php on line 109
[Fri May 15 09:30:44 2020] [error] [client 86.168.47.31:0] PHP Warning: Use of undefined constant TDSP_THEME_PATH – assumed ‘TDSP_THEME_PATH’ (this will throw an Error in a future version of PHP) in /home/sites/terryally.com/public_html/newsroom/wp-content/plugins/td-composer/td-composer.php on line 113
3) When I try to enable thumb on module/blocks for the template. These were not saving. I installed Regenerate Thumbnail but this was not “seeing” the sizes.
I deleted the entire site and started from scratch with a clean install of WP then installed Newspaper X. Rather than importing the entire site including plugins, I just imported the pages/posts and media. That works.
But that is a workaround. My concern is when I try to go live with Newspaper X on EAsyWP that it might malfunction. The reason that I raise this is because they have a must-use plugin which is proprietary and it blocks plugins like WP-super-cache which is recommended by TagDiv.
My server specs are:
WordPress 5.4.1
Apache/2.4.41 (Unix)
php.ini memory limit: 512MB
PHP version 7.3.15 (EasyWP runs and requires 7.3)
MySQL version 5.0.12
You can see full specs at http://www.terryally.com/info.php.
Any help would be appreciated.
Sorry …
After posting this query I found other posts about EasyWP and it would appear that there is a problem with Newspaper operating on EasyWP sites.
If you can confirm that for me, I will move house.
Indeed our theme is not working well with EasyWP, sorry!
Also we recommend to follow the guide for theme requirements for each host you are using
Than you for your understanding!
Thanks and no problem.
I will move from EasyWP.
Regards
Terry
