Hello @Jolie!
In order to avoid misunderstandings, please provide more information(screenshots/video) about what exactly you need to achieve or what is the issue there and your website link.
Hi Bettina,
Thank you for a quick response, here’s the screen cap:
https://app.screencast.com/y5bWlYVnVopFb
Description:
– We use the TagDiv composer ‘Slide’ module to display Recent Posts
– We want to Pin/Sticky ONE post as the FIRST post of the slide (no matter how old this post is).
Currently, we solve this problem by changing the DATE of this post so it’s always the most current and always displays as the first slide, but this is not sustainable in the long run.
Thank you for your suggestions in advance.
Hello @jolie!
You can pin posts by writing their ID here: https://prnt.sc/T8nYbP9csdZJ So, always display the same post.
Also, you can use the feature offset: https://forum.tagdiv.com/offset-feature/
Unfortunately, you cannot display only the first post “pinned” and the rest in the same element.
Hello @jolie!
For customization and other services, you can contact our custom work team here: https://tagdiv.com/premium-customization-services/.
