Strange problem after updates to Newspaper 9.2.2
I ll try to explain what happened this morning
0. I already had installed Nespaper 8.7 site with Multi-purpose set pages and visual edited with tagDiv Composer
1. i have updated WP to newest version 5.01
2. Everything worked with all additional plugins as it was before point 1, except page where i had tagDiv Composer made block showing all posts sorted by newest first and with Load more option. This page suddenly gave white blank page
3. I thought that maybe its because new WP and i need new version of Newspaper theme, so i downloaded it from Envato and installed it (9.2.2)
4. I ve activated theme and suddenly all pages turn blank white, even admin page. Managed to fix this and at least to get admin page by renaming manually Newspaper theme folder.
5. Then I thought that its maybe because of plugins that goes with Newspapers, so i reinstalled tagDiv Composer and others td’s with those provided files in installation
6. Finally i have following situation:
– only tagDiv Composer is activated, of all plugins, site works (w/o some additional functionalities which other plugins provide)
– if i activate Classic Editor plugin and/or td speed booster, site still works
– if i activate any other plugin, even td Social counter to not mention other as those important Wordfence Security, Yoast and similar, entire site goes again in white blank pages
I ve tried to make theme inactive, deleted Newspaper folder and reinstalled it again. Problem hasn’t changed.
What to do? What could be so wrong? I m not skillful with this and WP, just common user.
  • This topic was modified 7 years by brue.
Just to add – if i deactivate td composer, all other plugins work and there is not a single blank white page error, but then entire content of the site, created with composer is messed, and it gives warning on the opened page that one important plugin is deactivated.
So it looks like that td composer is for some reason in conflict with almost all plugins… even to Akismet Anti-Spam (just as example)
  • This reply was modified 7 years by brue.
Since i have 4 Newspaper themes, i ve tried to check on one testing site, which is not developed yet. Simple front page, not designed with composer, just text.
As soon as i installed new version of Newspaper theme, all plugins got in conflict and cannot be activated if td-composer is activated, i.e. theirs activation leads to white blank pages.
That can be caused by low WP memory, we recommend a value of 256M
Be sure to add the code provided at the end of the guide in the htaccess file, also check all the other parameters mentioned in it. Your hosting provider should be able to do this for you if needed.
Most theme and theme plugin issues are caused by insufficient resources. Please let us know if the problem is solved after doing this.
Hi Simion,
thanks, it was exactly that. I ve added necessary line in wp-config file and now it works as it used to.
Thanks again.
Best regards,
Bojan
