This was just a suggestion to make the page for Business Directory smaller, now is not need to set each section in a new page, it will be a lot for improvements if you set the page in 2 or 4.
Also the hamburger menu is not working because you’ll need to wait until entire page will be loaded only after that this will work.
For php version we recommend to use php 7.3 but most of version of php7.4 are working too.
Also if you want to optimize your website you an try these guides from here:
-> https://tagdiv.com/how-to-increase-page-loading-speed/
-> https://forum.tagdiv.com/topic/optimize-script-to-improve-site-speed/
-> https://www.infophilic.com/get-almost-100-pagespeed-newspaper-theme/
–> https://forum.tagdiv.com/topic/a-few-tips-for-newspaper-x-speed-high-cpu-usage-issues/
Also there are some users that recommend to use Autoptimize and EWWW Image Optimizer
Hope this will help you!
Hi Calin,
Can you please explain in more detail your reply about setting the page in 2 or 4 ??… as I don’t understand what you mean?
As I said this problem has to be resolved the best way for users, as obviously how it is now is not working.
The majority of users will view the site on a mobile.
I can make a separate page for every sector, but thats over 100 pages!!, is this the best way??, or an I going to incur the same problem?.
Kind Regards
Mark
What I mean above is that you have right now a very big page and if you set haft of the page content in another page you’ll get better results, or to set the content from that page in 4 pages for example if you have 100 sections then make 4 pages with 25 sections, this will improve the website.
Also what you can try is to find a way to optimize your website to load faster. here are some links that maybe can help:
Hi Calin,
Thanks, ok I get the splitting up the page into 4 say A-Z pages. I would require to add new code though to enable the scroll effect in the different pages?
Do you think creating a separate page for each sector ‘100 pages’ would cause problems? .. or not?.. I think it would probably take me the same development time.
Kind Regards
Mark
Normal there should be no problems also if you need help with something just let me know!
A tip for you, if the page was made with tagDiv Composer, use two tab browsers and use the copy and past from mouse or buttons (like on windows), in this way it will go faster -> https://i.imgur.com/8G8eTCS.jpg
Hi Calin, trust you are all well.
I have started to add individual pages for each profession as you can see.. the support login is still the same as before or go to
https://www.ircatoday.com/istead-rise-co-op-staff-taking-on-mountain-of-mind-challenge/ for an example.
But the column width ‘4 columns’ is to short, as you can see, the profession titles are not on same line!..can some code be added to lengthen this please?
Regards
Mark
If you want that the title from that sub-menu to be display in one line, then you need to change the min-width -> https://i.imgur.com/oxzYlgh.png
.menu-item-1269 > .sub-menu li{
min-width: 210px;
Let me know the results!
Hi Calin,
There is one major concern!
I have tested the Business Directory, on Safari and Chrome desktop browsers
Chrome is fine, but Safari, under the MOBILE SERVICES ‘sub menu’ no professions are showing ?… I have not experienced this before in WordPress.
The same on Safari tablet, but mobile phone is fine ?
Please can you test yourself
Very strange?
Kind Regards
Mark
Hi Calin,
I did move the MOBILE SERVICES section under ‘memorial hall’ menu, as a test and the sub menu’s work fine!
This is only one column … so perhaps it has something to do with the 4 columns, which the BUSINESS DIRECTORY obviously is, now we added the code ??
Kind Regards
Mark
Also Calin,
The MOBILE SERVICE section needs to in one column only, this might solve the problem.
Its definitely not a browser issue, I look forward to your solution.
Thank you
Mark
Hello !
We have inspected your website and everything seems to be working perfectly as you can see here: https://www.screencast.com/t/wjxg2v2Wox
Hi Vlad,
Thanks for the reply, but its a desktop issue that Calin has been working on for the Business Directory.
I shall wait for his response.
Kind Regards
Mark
Hi Vlad,
This is an ongoing issue!, I have just renewed support for another 6 months!.
How can this particular issue not be covered by support team?..when its ongoing!
Calin has asked me to reply with the results!
So I am replying to Calin?
Regards
Mark
