Suddenly I can't edit my published posts. Is it because Gutenberg? How do I fix?
When I try to edit a published post it gives me a blank page with the following box
The editor has encountered an unexpected error.
Attempt Recovery
Copy Post Text
Copy Error
Does this have something to do with Gutenberg? It just started happening right after Gutenberg was implemented. How can I fix this?
Please make sure that you have the latest version of the theme
Also please add this in your .htaccess
https://www.screencast.com/t/FswObjqqmr7
Please make sure that this is not a plugin conflict, please deactivate all non theme plugins, clear all cache and try again!
Please make sure that the theme system status is configured as mentioned in the requirements guide. Please follow the guide carefully
If there is still a problem, please provide a link were I can inspect it!
