System Status Issue
Hi I am getting the following message for our page at https://infomeddnews.com
Please advise how to fix it. The message reads:
v4.9 – Disabled – incompatible plugin detected: add-category-to-pages/add-category-to-page.php
I believe that message is related to the Speed booster plugin. This plugin has a predefined list of plugins defined. If it detects there are other plugins active, it will disable itself. This is meant because the Speed booster may cause issues for other plugins.
This check that it makes can be disabled by editing the plugin
– https://forum.tagdiv.com/topic/tinymce-advanced-and-other-various-disabling-speed-boster/
